PSoC™ 4
moshc_4060821
New Contributor II
i am working with Psoc4 Ble pioneer kit.
i want to generate a WDT based interrupt after every hour. so to do that i have i have used global signal component.
this is my code
CY_ISR(WDT_ISR_handler)
    WDT_ISR_ClearPending();
    HW_Init();
    /* Starts RTC component */
    RTC_Start();
    /* Set RTC time update period */
    RTC_SetPeriod(1u, SYSTICK_EACH_1_HZ);
    RTC_ClearAlarmStatus() ;
    RTC_SetAlarmHandler( alarm_handler ) ;
    RTC_SetAlarmMask( RTC_ALARM_SEC_MASK ) ;
    WDT_ISR_StartEx(WDT_ISR_handler);
    for(;;)
please find attached screen shots for WDT2 clock configuration.(currently i am testing it with only 4 seconds)
so my problem is first time interrupt is generated after 4 seconds but then it could not clear and the pending register or something.
please guide me.
moshc_4060821
New Contributor II
hi
i have solved the problem.
this is my code.
      CySysWdtClearInterrupt(CY_SYS_WDT_COUNTER2_INT);
    HW_Init();
    RTC_Start();
     /* Enable WDT0 counter */
    CySysWdtEnable(CY_SYS_WDT_COUNTER2_MASK);   // WDT=PeriodicTimer
    WDT_ISR_StartEx(WDT_ISR_handler); // Start ISR for pin toggle
    CySysWdtEnable(CY_SYS_WDT_COUNTER2);
    for(;;)
thanks for helping.
Mohit
odissey1
Honored Contributor II
mohit.shukla,
Check this WDT interrupt and initialization code. Project link
ButtonSw32: button switch debouncer component
/odisssey1
// The interrupt handler for WDT counter 0 interrupts.
CY_ISR(WdtIsrHandler)
    //WdtIsr_ClearPending(); // Clear Interrupt (not needed)
    #if(CY_IP_SRSSV2)
        CySysWdtClearInterrupt(CY_SYS_WDT_COUNTER0_INT); // Clear WDT0 interrupts state
    #else
        CySysWdtClearInterrupt();
    #endif
    Button_1_CheckStatus(); // poll Button_1
void Initialize(void)
    CyGlobalIntEnable; //enable global interrupts.
    #if(CY_IP_SRSSV2)
        CySysWdtEnable(CY_SYS_WDT_COUNTER0_MASK);   // WDT=PeriodicTimer
    #else
        CySysWdtEnable();
        CySysWdtUnmaskInterrupt();                  // WDT=Watchdog
    #endif
    WdtIsr_StartEx(WdtIsrHandler); // Start ISR for pin toggle
int main()
    Initialize();
    for(;;)
moshc_4060821
New Contributor II
hi odisssey1
thanks for your reply.
but it still doesn't work.
i have configured clock WDT2 to generate 4 seconds interval using WCO:WDT Issue.png
and this is my code.
    #if(CY_IP_SRSSV2)
    #else
    #endif
    HW_Init();
    RTC_Start();
    #if(CY_IP_SRSSV2)
    #else
        CySysWdtEnable();
    #endif
    for(;;)
and i have put a break point in ISR function...first time interrupt generated after 4 second but then it it is generating continuously.
please help...
moshc_4060821
New Contributor II
hi
this is my code.
    HW_Init();
    RTC_Start();
    for(;;)
thanks for helping.
Mohit
