warp error
saga_1136906
10 replies posted 10 questions asked 10 sign-ins
while I was working with Psoc Creator 4.4 the IDE closed itself and started an installation of Psoc Creator 4.4. Locked by itself. So I tried to Repair by Psoc installer. I see the message attached. Restarted PC and try to reinstall Psoc Creator 4.4: same message. I have rights of administrator. Whats happened?
Thanks for helps.
saga_1136906
Hi Krupashankar,
disabled antivirus -> installed psoc 4.4 -> reenabled antivirus -> solved!
Krupashankar
500 replies posted 50 likes received 25 likes received
Hi @saga_1136906,
The issue you are facing seems like an error in the installer file. Can you kindly
  • Download the installer again
  • Login as administrator, or run the installer as administrator
As an additional resource, please refer to this KBA: Troubleshooting PSoC® Creator™ Issues - KBA217546.
Krupashankar
saga_1136906
Hi Krupashankar,
Krupashankar
Hi @saga_1136906,
Thanks for posting the answer.
Krupashankar
