So, this is my first attempt at using PSOC 4 series MCU, for the starter I looked at youtube for help, and follow this Video,
Well it was not an easy job but, I followed all instructions as in the video but I am getting an error
Build error: undefined reference to `CapSense_CSD_Start'
I am using PSoC creator version 4.4, I am using MCU CY8C4014SXI-421 16 pin soic, I am not sure why is the error, mostly it is a linking error, but I don't know how to resolve it.
Also if possible anyone can guide me to documentation for starting with CY8C4014SXI-421 with the MCU family and getting started with Capsense.
- build error
Hi @admin_hun_main,
Firstly, we recommend you to use the latest version of CapSense component - CapSense v7.0.
Double click on the CapSense component and click on the "Datasheet" button. This will open the component's datasheet. Head to the APIs section to get a detailed list of all APIs supported by the component.
cystatus CapSense_Start(void) - This is the function to be used to initialize the CapSense component. The same has been shown in the video too.
Here are some resources which you can refer to:
1. Getting started with CapSense
2. Datasheet of CY8C4014SXI-421
3. PSoC® 4 and PSoC 6 MCU CapSense® Design Guide [a detailed document of CapSense]
4. You may refer to code examples by going to File->Code examples in PSoC Creator. For ModusToolbox, you may find the code examples here.
Thanks and regards,
Nikhil
Hi @admin_hun_main,
Thanks and regards,
Nikhil
