I use the device Cy8C4013LQI.
I must disable all components for power saving.
So I followed the instruction to change the debug interface to from SWD to GPIO.
Programming should always be possible.
But after download the firmware I can not connect the device anymore.
I use Segger-Jlink with the newest Firmware and software.
Here I found a similar problem.
http://forum.segger.com/index.php?page=Thread&threadID=2945
There are speaking about the version p, but in the download area only available version j.
So - how can I fix the problem? Now I blocked 3 prototypes.
rola_264706
Level 8
Level 8
Cypress doesn't support this software for programming the device and recommends Psoc Creator programming.  I would suggest that you open a case with Cypress to see if they have a solution.
Yes, I will open a new case.
I think, the problem is by Segger. Because the same problem was on a other type of Chips (BLE).
The reason why we use the Segger is, that we have for programming a big platform of severall industrial programmer from Segger and must use them for production programming.
