I am currently working on CY8C4124ZI-S433 microcontroller. According to the datasheet the pin 4[0] and 4[1] support scb_uart[0] but when I try to assign the pins as uart using the psoc creator software, the software is restricting the uart pin assignment to the mentioned pins and rerouting the pins to P0[4] and P0[5] (scb_uart[1] as per datasheet). Attached is the screnshot of the datasheet instructing availability of scb_uart[0]. Any suggestion on the would be appreciated.
PSoC 4 MCU
Hi @saurabh
The selected MPN, CY8C4124AZI-S433, only has two SCB blocks - SCB1 and SCB2. SCB0 is only valid in some MPNs in the family and therefore, it is not supported by CY8C4124AZI-S433. Please refer the snippet from the ordering information section of the datasheet -
Hari
Hi @saurabh
Hari
