Hi
I try to receive 9 bit Data on uart.
I know that the 9th data is in the Mark/Space reg.. Unfortunately I do not find out how I got there.
An other problem is that I not receive a Buffer sice. what am I doing wrong? I use the uart(SCB-Mode) v4.0 on the CYBLE-224116-01
SW:
CyGlobalIntEnable;
UART_2_Start();
for(;;)
if(UART_2_SpiUartGetRxBufferSize()!=0)// data received?
test_pin_Write(1); //set pin 1
ZentralIn=UART_2_UartGetByte(); // read out 8 bit
//read out 9th data??
thanks
Heidi
So I've tried a lot now. I am now convinced that it can be easily read out of the function. Sometimes it is better not to read the datasheet, then I would have to tried it immediately.
uint32 test;test=UART_2_UartGetByte();
if (<= 0x1FF)//no error
if (test>=0x100)//bit 9 set
else//bit 9 clear
else// error
