4DescarTes
First question asked Welcome!
Hi, I have a CY8C4148AZI-S455 microcontroller, I am connecting it to my PC via J-Link. And I can successfully program the controller, with my code written in PSoC creator. I am turning an LED on, and that is how I can see the connection is successful. In my code, I have some variables, and I want to see their value.
Here you can see my app, I uploaded the .elf file. When I press run,
 this is coming, I couldn't find an error such as that. What can I do?
LinglingG_46
500 solutions authored 1000 replies posted 10 questions asked
LinglingG_46
1: Do you refer to the linker file:
https://www.infineon.com/dgdl/Infineon-Tooling_Micrium_uCProbe_XMC_getting_started-GS-v01_00-EN.pdf?...
2: Do you use the Micrium UC probe XMC ?
