I am working on project of touchpad. My one finger using cursor move and click are completed. But now I am facing problem for scrolling using one and two finger and Zoom IN /Zoom Out. So please suggest me.
PSoC 4 MCU
Can you please describe the issue you are facing? We have support for gestures built-in to the CapSense component and you can use the same for your application.
You need to enable the required gesture and you can get the same in the application code as well. Please refer to the component datasheet for a brief description of the parameters that you need to set.
Hari
Hari
