Hi I am reading keyboard.c of CY5672 Demo code, and feel a little confuse. could anyone explain the code below?
since,
index = i+j*8*ROWS;
NO_COLUMN_PORTS=1,
ROWS=3,
why in Keyboard_Add_Queue(index);,static KeyElement keyQueue[KEY_QUEUE_LEN]; keyQueue is defined with length of 18? what is the purpose of the definition of index?
static void Keyboard_Detect_Keys(void)
uint8 i, j, index, col, p_col;
/*By checking row by column key status detect which key is pressed or released*/
for(i=0;i<ROWS;i++)
/*Check for any Ghost key detected*/
if(!Keyboard_Detect_Ghost(i))
for(j=0;j<NO_COLUMN_PORTS;j++)
index = i+j*8*ROWS;
#if (NO_COLUMN_PORTS > 1)
col = (curColumnStatus
p_col = (col & prevColumnStatus
col = (col & curColumnStatus
#else
col = (curColumnStatus ^ prevColumnStatus);
p_col = (col & prevColumnStatus);
col = (col & curColumnStatus);
#endif /* (NO_COLUMN_PORTS > 1) */
while((col != 0) || (p_col != 0))
/*If column value is 1 then update Keyboard queue with index*/
if(col & BIT_0_MASK)
/*If previous column value is 1 then update un-pressed status for status change
in column*/
if(p_col & BIT_0_MASK)
Keyboard_Update_Release_Key_State(index);
index+=ROWS;
col = col>>BIT_1_POSITION;
p_col = p_col>>BIT_1_POSITION;
prevColumnStatus
#else
prevColumnStatus = curColumnStatus;
BLE
A:index represent the key:SW1-SW10, like index-0 represent SW1.
API: Keyboard_Add_Queue(index); shall use the the index to update Key's status(if key.index have already in queue) or add key to Queue(if key.index is not in the queue.).
