Greetings Sir,
Can you please provide the Size , thickness and what is the material used for touch panel in case we are using
Hi @Spandana-S
The CapSense touch panels can be prepared on a standard FR4 PCB. Sensor designs on FR4 and Flex PCBs are supported where the typical thickness of FR4 is 1.6 mm and Flex PCBs are 0.1mm. In case you want a transparent touch panel, the design must be made with an ITO material .
Please let me know if these meet your requirements.
Hari
Hi @Spandana-S
Hari
