recording using mems mic
joje_4561541
Hi I m trying to record using mems mic connected with cypress psoc4.
I thought the output would be in wav file but it's in voltage.
Is there anyway I can change the output to wav file?
Or is there anyway to convert the output into wav file?
Ekta
750 replies posted First like given 250 solutions authored
Hello Joon,
Thank you for contacting Cypress Technical support.
Can you let me which software you are using for recording?
We recommend you to use an audio recorder software tool, such as Audacity. After the recording is done using audacity you can save the recorded audio as wav file.
For this in the Audacity window goto File> Export> Export as WAV
Thanks and regards
Ekta
Ekta
Hello Joon,
Thanks and regards
Ekta
