DaEr_349131
25 likes received 50 sign-ins 5 comments on KBA
What would be the most efficient way to control pins from Verilog with minimal cpu overhead?
example, Port 12 shown in the picture below.
odissey1
Level 9
Level 9
Apart from the latency, DMA transfer from Control Register, instantiated in verilog,  to the Port should work.
odissey1
RodolfoGL
250 solutions authored 250 sign-ins 5 comments on KBA
Depends how you want to update the pins. If you just want to place pins from different ports all together, you can simply use a control register and link all pins to this control register. The CPU can simply update the control register to modify the state of all pins connected to it.
Firmware only pins can not be driven by PSoC hardware, neither control register nor verilog.
Bob
odissey1
Level 9
Level 9
odissey1
smart, will try!
