psoc4 eeprom fixed flash address discarded input sections
lili_285866
Distributor - Zenitron(GC)
5 replies posted 5 questions asked 5 sign-ins
Hi Sirs,
We use PSoC4 emulated EEPROM they compiler after get error_address.jpg in *.map file,I find .My_section is by Discarded input sections ,if the use main.c replace this code ,I compiler again the address is normal (good_address) in .map file. Is this a bug in PSoC Creator 3.3? Is there a way to solve this problem?
Lin
Alakananda_BG
50 likes received 250 sign-ins 250 replies posted
Hi Lin,
As we observed you are using an old version of Emulated EEPROM as well as old version of PSoC Creator
Please use the latest versions for both.
I have attached the example project for Emulated EEPROM for your reference
Alakananda
Alakananda
lili_285866
Hi Sirs,
I find this issue with comilper optimization level affect fixed  eeprom , Does anyone know why?
Lin
Alakananda_BG
Hi Lin,
Alakananda
Alakananda
