PSoC™ 4 Forum Discussions
ThBi_3905606
10 replies posted 10 questions asked 10 sign-ins
I do not understand why I can not drag component on top design...
in new or old project
DennisS_46
50 solutions authored 50 sign-ins 100 replies posted
There is a possibility that you are in a component drawing mode. If this is the case, click on topdesign.cysch in the project explorer.
If that doesn't work, click on Window in the Creator toolbar, then click on Reset Layout, this will revert to the default state.
If that doesn't work, let me know and we will find next steps.
---- Dennis Seguine, PSoC Applications Engineer.
DennisS_46
Bhamy
Moderator 5 solutions authored 50 sign-ins First like received
Hi @ThBi_3905606 ,
Did you get some time to check the suggestions provided by @DennisS_46?
Bhamy Narasimha Shenoy
ThBi_3905606
It is working, now,
I did an update of cyboot component, but I needed to reboot my computer? I can not say what happened exactly,
maybe the reboot was enough, may be I was on this drawing mode you tell  me about, I can not be sure.
thank you
