psoc 4Y8CKIT-145-40XX Kit
LaKa_4300241
Hi
I am using cy8ckit-145-40xx kit and connected external sensor. The shield in the sensor is taking signal which i dint want. Can you please suggest me some
pin in kit i can connect the sensor shield and that doesn't take signal.
Thank you.
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
You can download schematic of CY8CKIT-145-40XX from
=== CY8CKIT-145-40XX page ===
https://www.cypress.com/documentation/development-kitsboards/cy8ckit-145-40xx-psoc-4000s-capsense-pr...
=== schematic ==
https://www.cypress.com/file/443816/download
Then you can check which pin is not connected to particular use.
Yes, it is a time consuming task...
WARNING: Spoiler below
From what I tried following pins seem to be available
P1_7, P2_7, P3_7, P4_0, P1_0, P1_1, P1_2
Please DIY next time 😉
(added) OOPS!
If you read CY8CKIT-145-40XX_PROTOTYPING_KIG_GUIDE
In the page 35 and page 36, almost same table is available.
https://www.cypress.com/file/325536/download
BTW, to avoid this I often remove these shield wings so that I can use most of the pins.
As far as I  solder pin sockets they can be connected using jumper wires.
moto
MotooTanaka
Level 9
Level 9
=== schematic ==
(added) OOPS!
moto
Hi
I was using pin 4_0 for the shield. but still it takes signal.
Any suggestions?
Hari
Hi LaKa_4300241
Can you share the picture of the test setup and the position in the PCB where touching shield results in a touch being registered?
Hari
Hi
I have attached the pin setup pic.
Hari
Hi LaKa_4300241
By the test setup, I meant the physical sensor connection in the board and the location of the shield hatch. Please send a photograph of the sensors. The one shared now is the schematic from the top design and pin assignment.
A picture of the real "sensor" and the method of implementation would be helpful.
Hari
