Equip yourself to optimize PSoc4 MCUs for Evs at the EV Webinar. Click here to register.
PSoC™ 4 Forum Discussions
moshc_4060821
Hello
I am using psoc4 BLE pioneer kit.
I want to generate periodic ISR using RTC after every 24 hour.
Please guide me.
thanks
MOHIT
i have solve the problem.
thank you all for hellping.
here is my code.
int main()
    RTC_DATE_TIME alarm_time ;
    uint32_t sec, min, hour ;
    char str[128] ;
    init_hardware() ;
    sprintf(str, "RTC Alarm Test (%s %s)\n", __DATE__, __TIME__) ;
    UART_PutString(str) ;
    RTC_ClearAlarmStatus() ;
    RTC_SetAlarmHandler( alarm_handler ) ;
    RTC_SetAlarmMask( RTC_ALARM_SEC_MASK ) ; /* I only care for sec this time */
   //*for 24 hr alarm*/RTC_SetAlarmMask(RTC_ALARM_HOUR_MASK | RTC_ALARM_MIN_MASK | RTC_ALARM_SEC_MASK ) ;
  /*  RTC_GetDateAndTime(&alarm_time) ;
    /* create 00:00:15 as alarm_time */
    hour = 0u ;
    min = 0u ;
   sec = 45u ;
    alarm_time.time =
        (uint32_t)(hour <<   RTC_HOURS_OFFSET) |
        (uint32_t)(min  << RTC_MINUTES_OFFSET) |
        (uint32_t)(sec) ;
    RTC_SetAlarmDateAndTime( &alarm_time ) ; */
RTC_DATE_TIME MyAlarm;
    RTC_DATE_TIME testReadback;
    MyAlarm.time = RTC_SetHours( MyAlarm.time, 0 );
    MyAlarm.time = RTC_SetMinutes( MyAlarm.time, 0 );
    MyAlarm.time = RTC_SetSecond( MyAlarm.time, 45 );
    // Set the Alarm
    RTC_SetAlarmDateAndTime( &MyAlarm );
    while(1)
        if (alarm_flag) {
            alarm_flag = 0 ;
            UART_PutString("ALARM! ") ;
            print_time() ;
        CyDelay(200) ;
thank you
mohit
Yugandhar
1000 replies posted 5 likes given First comment on blog
Hello Mohit,
Please refer to the code example project "RTC_P4_SysTick_Example" in the PSoC Creator for basic operation of RTC.
P Yugandhar.
Although I'm not the one asked this question, I also wanted to know how to use alarm.
So I downloaded "RTC_P4_SysTick_Example" and tried, but I could not figure out how to use alarm function.
Then I tried to setup alarm with the project.
As I'm not patient enough to wait 24 hours, I set the alarm for 15sec each minutes.
I called RTC_SetAlarmMask() as
RTC_SetAlarmMask(RTC_ALARM_SEC_MASK) ;
But I think that for the 24 hours version, RTC_SetAlarmMask() should be called as
At least it seems to be working and alarm is triggered every minutes at 15 sec.
TeraTerm log
main.c
* File Name: main.c
* Version: 1.00
* Description:
*  This is the source code for the example project of the RTC_P4 component.
* Copyright 2015, Cypress Semiconductor Corporation. All rights reserved.
* This software is owned by Cypress Semiconductor Corporation and is protected
* by and subject to worldwide patent and copyright laws and treaties.
* Therefore, you may use this software only as provided in the license agreement
* accompanying the software package from which you obtained this software.
* CYPRESS AND ITS SUPPLIERS MAKE NO WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
* WITH REGARD TO THIS SOFTWARE, INCLUDING, BUT NOT LIMITED TO, NONINFRINGEMENT,
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
* RTC Alarm Test version
* Modified on 28-Mar-2019
#include <project.h>
#include <stdio.h>
/* Time: 10:59:50 */
#define TIME_HOUR           (0x10u)
#define TIME_MIN            (0x59u)
#define TIME_SEC            (0x50u)
#define TIME_HR_MIN_SEC     ((uint32)(TIME_HOUR << RTC_HOURS_OFFSET) | \
                             (uint32)(TIME_MIN  << RTC_MINUTES_OFFSET)    | \
                                      TIME_SEC)
/* Date: 03/28/2019 */
#define DATE_MONTH          (RTC_MARCH)
#define DATE_DAY            (0x28u)
#define DATE_YEAR           (0x2019u)
#define YEAR_MONTH_DAY      ((uint32)(DATE_YEAR  << RTC_YEAR_OFFSET) |\
                             (uint32)(DATE_MONTH << RTC_MONTH_OFFSET) |\
                                      DATE_DAY)
#if 0
#define DATE_MONTH_DAY_YEAR ((uint32)(DATE_MONTH << RTC_MONTH_OFFSET)   | \
                             (uint32)(DATE_DAY   << RTC_DAY_OFFSET)        | \
                                      DATE_YEAR)
#endif
#define SYSTICK_EACH_10_HZ  (10u)
#define SYSTICK_RELOAD      (CYDEV_BCLK__SYSCLK__HZ / SYSTICK_EACH_10_HZ)
/* Interrupt prototype */
CY_ISR_PROTO(SysTickIsrHandler);
volatile int alarm_flag = 0 ;
CY_ISR(alarm_handler)
    alarm_flag = 1 ;
void init_hardware(void)
    uint32 i;
    /* Starts SysTick component */
    CySysTickStart();
    /* Configure SysTick timer to generate interrupt every 100 ms */
    CySysTickSetReload(SYSTICK_RELOAD);
    /* Find unused callback slot. */
    for (i = 0u; i < CY_SYS_SYST_NUM_OF_CALLBACKS; ++i)
        if (CySysTickGetCallback(i) == NULL)
            /* Set callback */
            CySysTickSetCallback(i, SysTickIsrHandler);
            break;
    /* Starts RTC component */
    RTC_Start();
    /* Set Date and Time */
    RTC_SetDateAndTime(TIME_HR_MIN_SEC,YEAR_MONTH_DAY);
    /* Set RTC time update period */
    RTC_SetPeriod(1u, SYSTICK_EACH_10_HZ);
    /* Enable global interrupts */
    CyGlobalIntEnable;
void print_time(void)
    char timeBuffer[16u];
    char dateBuffer[16u];
    uint32 time;
    uint32 date;
    /* Get Date and Time from RTC */
    time = RTC_GetTime();
    date = RTC_GetDate();
    /* Print Date and Time to UART */
    sprintf(dateBuffer, "%04lu/%02lu/%02lu", RTC_GetYear(date), RTC_GetMonth(date), RTC_GetDay(date)) ;
    sprintf(timeBuffer, "%02lu:%02lu:%02lu", RTC_GetHours(time), RTC_GetMinutes(time), RTC_GetSecond(time));
    UART_PutString(dateBuffer);
    UART_PutString(" | ");
    UART_PutString(timeBuffer);
    UART_PutString("\r");
* Function Name: main
* Summary:
*  At the beginning of the main function, the Systick timer starts and
*  initializes interrupt generation every 100 ms and sets the current Date and
*  Time using API. After Data and Time from RTC is obtained, print them to UART
*  in the cycle.
* Parameters:
*  None.
* Return:
*  None.
int main()
    char str[128] ;
    init_hardware() ;
    hour = 0u ;
    min = 0u ;
    sec = 15u ;
    alarm_time.time =
        (uint32_t)(sec) ;
    while(1)
        if (alarm_flag) {
            alarm_flag = 0 ;
            print_time() ;
        CyDelay(200) ;
* Function Name: SysTickIsrHandler
* Summary:
*  The interrupt handler for SysTick interrupts.
* Parameters:
*  None
* Return:
*  None
void SysTickIsrHandler(void)
    RTC_Update();
/* [] END OF FILE */
moto
hi motoo tanaka
thanks for helping me. by using your method i am able to generate alarm @  15th second.
but as i have modified the second 15 to 45 alarm is generated on 33rd seconds. i could not understand why.
this is the code
int main()
    char str[128] ;
    init_hardware() ;
    hour = 0u ;
    min = 0u ;
   sec = 45u ;
    alarm_time.time =
        (uint32_t)(sec) ;
    while(1)
        if (alarm_flag) {
            alarm_flag = 0 ;
            print_time() ;
        CyDelay(200) ;
please guide me.
mohit
here is my code.
int main()
    char str[128] ;
    init_hardware() ;
    hour = 0u ;
    min = 0u ;
   sec = 45u ;
    alarm_time.time =
        (uint32_t)(sec) ;
    // Set the Alarm
    while(1)
        if (alarm_flag) {
            alarm_flag = 0 ;
            print_time() ;
        CyDelay(200) ;
thank you
mohit
Dear Mohit-san,
Thank you very much for your correcting my code!
Now I learned how to set the time correctly.
4-Apr-2019
Motoo Tanaka
