Mar 26, 2018
12:45 PM
Mar 26, 2018
12:45 PM
in psoc creator, if you use the schematic tool to create 4 input switches, and name them SW1, SW2, SW3, SW4, the tool autogenerates 4 instances of the exact same code, the only difference is the name of the function, it creates API SW1_Read SW1_Write, SW2_Read, SW2_Write, SW3_Read SW3_Write, SW4_Read, SW4_Write,
Is there a way to get the tool to generate one copy of the API then you pass it the port. for instance just having Read_Port, and Write_Port, then pass the port as variable. instead of having 4 coppies of the same code?
Labels
BLE
