D_Sd_3235936
Level 4
Level 4
25 sign-ins 50 questions asked 25 replies posted
Regarding this post: http://www.cypress.com/comment/199841 .
I would like to use the lite iprintf to send 64bit parameters. Currently it only supports %d for 32bit integers.
is it possible?
if so, can you assist with code?
odissey1
Level 9
Level 9
DimaSidi,
Attached is a demo project printing 64-bit integers using custom formatting procedure (without "stdio.h" and "sformat"). Project compiled using PSoC5LP (KIT-059), but formatting procedure will work of PSoC4 same way. You need to update corresponding UART component and assign pins.
/odissey1
himam_31
Currently we do not have a code with this requirement.
Hima
odissey1
Level 9
Level 9
DimaSidi,
/odissey1
