PSoC™ 4 Forum Discussions
RaKu_3095736
First like given
hi all, I am counting square wave on pin no P4[5] or P4[4] based on rising edge or falling edge interrupt,
but it's not working on P4[5] or P4[4], the same code is working on any other pins
I am using PSOC4.2 and CY8C5268AXI-LP047TQFP-100-M
I changed the drive mode of both the pins to high impedance digital and its start working
Thank you
LinglingG_46
10 questions asked 5 questions asked 250 sign-ins
The two pins are GPIO.
Can you attached your test project here? Whether the Pin in your board has connected anything in your board? If so, remove them.
Thank you
