ShMi_1495391
Level 4
Level 4
50 replies posted 25 replies posted 10 replies posted
Re: PSoC4100SP:SPI(Master) Slew rate change
The answer in this thread is to change the register(GPIO_PRTx_PC[25]).
Is it okay to change the setting of Pin ?
Ekta
750 replies posted First like given 250 solutions authored
Yes, its okay to make change pin settings directly. This in turn changes the value of the defined register (in this case the value of GPIO_PRTx_PC[25]). This is done to make the task easier. Directly changing the register value can be used to configure components during runtime.
Best Regards
Ekta
Ekta
Best Regards
Ekta
Thank you for your answer.
