RoMa_4791621
I've been referencing two example codes; BLE Temperature Measurement Example Project & PSoC_4_BLE_CapSense_Slider_LED.  I want to make ADC readings of a thermistor and report the ADC codes in a custom GATT profile.  The attached project advertises fine but the central device does not find the characteristics and disconnects.  I need help choosing the API calls to complete the remaining tasks. - thanks in advance.
SudheeshK
250 sign-ins First question asked 750 replies posted
I tested your project using CY8C4248LQI-BL583 device. I was able to connect to it using CySmart app and see the available services. But, you have mentioned that you are not able to see the available services from your central device. Could you please provide more details about your central application?
Please see the example projects available in following link, PSoC-4-BLE/100_Projects_in_100_Days at master · cypresssemiconductorco/PSoC-4-BLE · GitHub . They will help you to understand the usage of APIs for different applications.
Thanks and Regards,
Sudheesh
SudheeshK
Thanks and Regards,
Sudheesh
Thank you, I will check it out. For central I am using nRF connect Nordic
app on android. When I bypassed the ADC conversion code section I could
see the services.
On Wed, Oct 21, 2020 at 3:22 AM SudheeshK_26 <community-manager@cypress.com>
