Dears
I want be able to read and do all setting like is possible with the "CapSense Tuner" but with an external Microcontroller (via I2C). I use the PSoC4000S Kit with 4045 Controller.
As the CapSense Tuner already communicate via I2C (+ to USB converter), I think there should be somewhere a Documentation about the Register-Adress and Settings so that I can simply read and control the specific values and settings via an external Microcontroller with I2C Interface?
thank you
allenk_26
5 replies posted Welcome! First solution authored
The register map might be different per each project.
I guess you can get your register map using this menu.
please open the configure menu of CapSense component and export 'Register Map' by clicking the "Export Register Map" button.
I guess you can access from external micro-controller.
Thank you.
Allen Kim.
allenk_26
Thank you.
Allen Kim.
fantastic, great tool 🙂 I think exactly what I was looking for...
allenk_26
I am happy you got what you want.
Happy journey with PSoC!!!
