Can we upgrade/edit the firmware of e78-868ln22s LORA end node using kitprog3 in modustoolbox or psoc creator??
Papendu
I am afraid, we don't have a standard hardware/kit integrating the PSoC and e78-868ln22s LORA. Hence, we don't have software for this running on Modus ToolBox or Creator.
If there is any kit (having a PSoC in it) provided by eByte then we recommend you to contact eByte for the firmware.
Let us know if you have any other doubts
Hi, I did not get the exact solution from e-byte. However, after a whole lot of research, i found the answer online.
Papendu
