PSoC™ 4 Forum Discussions
GuoXiangH_21
10 replies posted 5 replies posted 5 questions asked
Dears:
     customer use PSOC as main controller,and they need to modify the SCB bandrate when running application
     do we have the API can fit the requirement ?
MotooTanaka
Level 9
Level 9
Although I have not tried it by myself, following strategy might work
(1) Set the SCB module has "Clock from terminal"
(2) Connect clock to the SCB module
(3) Configure the Clock for fractional divider
  check "Use fractional divider"
(4) Then an API called Clock_SetFractionalDividerRegister will be available.
In my sample the name will be "Clock_12MHz_SetFractionalDividerRegister",
and I'm not sure if "UART" was right sample for this kind of test...
moto
MotooTanaka
Level 9
Level 9
moto
