- Email to a Friend
Is there a test program? I want to test the bluetooth communication。
- Email to a Friend
The dongle can be used with Cypress's CySmart Windows tool to test and debug BLE devices. Please install the CySmart and program BLE_4_1_Dongle_CySmart_128K.hex available at: C:\Program Files (x86)\Cypress\CySmart\1.3\dongle\CY5670\BLE_4_1_Dongle_CySmart_128K.hex
P Yugandhar.
- Email to a Friend
The website can't be opened, can you send it to me?
- Email to a Friend
- Email to a Friend
Phone can't find bluetooth device。
- Email to a Friend
The CySmart dongle is used with CySmart Windows tool to test and debug BLE devices. The CySmart BLE 4.2 USB Dongle is factory-programmed to work as a BLE GAP Central device, allowing you to debug BLE applications. To use this dongle as GAP central role, you have to install the Cysmart Windows Tool and connect the dongle as shown in attached image.
If you want to use this dongle as peripheral, then you need to program any of the BLE peripheral project. In PSoC Creator 4.2, open any of the BLE peripheral project(ex. BLE_FindMe) and select the device 'CYBL10162-56LQXI' in Device Selector ( Goto Project -> Device Selector and select 'CYBL10162-56LQXI' from the list.
Please refer to this Github link for some examples on PSoC4 BLE.
I have attached the BLE_FindMe project and hex file.
P Yugandhar.
- Email to a Friend
cySmart, I can't download it, can you send me one?
- Email to a Friend
thank you very much! The test worked great! Is there a routine to use the bluetooth module in the chip as a serial port?
- Email to a Friend
Please refer to the Day020_BLE_UART code example from the GitHub link. Please let me know if this helps your requirement.
P Yugandhar.
- Email to a Friend
Your website won't open can you send me the cySmart software?
- Email to a Friend
There is a problem with your website, can you send me all these routines?
- Email to a Friend
Can you send me these programs? Your website cannot be opened.
- Email to a Friend
Please get the Cysmart software in this drive link and check the attached Day020_BLE_UART project.
P Yugandhar
- Email to a Friend
I got an error while debugging the uart_ble routine, how to fix it?
- Email to a Friend
Please update the components to latest version. In PSoC Creator-> Goto Project ->Update Components as shown in below image.
P Yugandhar.
