Jul 21, 2022
07:48 PM
Jul 21, 2022
07:48 PM
Jul 28, 2022
02:48 AM
Jul 28, 2022
02:48 AM
Please set the 'Debug Select' to SWD in 'Design Wide Resources' as shown in attached image. Please refer to the attached 'PSoC4_BLE_Capsense_Proximity' project.
P Yugandhar.
Jul 21, 2022
11:15 PM
Jul 21, 2022
11:15 PM
Please check that the 'Debug Select' setting under 'Programming/Debugging' in the 'Design Wide Resources' is set to SWD pins. When you select SWD, pins P0[6] and P0[7] will be dedicated for debugging only and you will not be able to use them as GPIOs.
Are you using the MiniProg for debugging ? If yes, then please let me know the version which you are using.
If possible, please share your project for testing at our end.
P Yugandhar.
Jul 24, 2022
08:23 PM
Jul 24, 2022
08:23 PM
Jul 26, 2022
02:21 AM
Jul 26, 2022
02:21 AM
Could you please share your project for testing at our end ?
P Yugandhar.
Jul 27, 2022
10:47 PM
Jul 27, 2022
10:47 PM
Jul 28, 2022
02:48 AM
Jul 28, 2022
02:48 AM
