Getting errors I cannot resolve trying to configure a CYBLE-212006-001 project.
Please see the attached bundle.
Here are images of the error and the reason I cannot understand what the fix it.
BLE
Please update the boot component to the latest one i.e. cy_boot 5.90 .
The bundle you attached contains clock error. When I tried to open the clocks tab, I am not able to open it. I think the workspace is not archived properly. Please use complete archive option while archiving.
The clock error basically says that the WDT is enabled as auto-generated. Please change it to user provided.
Please find the attached document which helps you to configure WDT in case you require it.
Please attach the complete project if you have more queries.
Ganesh
Ganesh
