Our product uses PROC BLE Module (CYBLE-022001-00), and we are running some emissions test at the Test Labs,And we are using CYSAMRT to run the tests.
And Test Lab folks want the way to control the BLE module Operating frequency. I think there is a CHANNEL MAP selection command under SEND COMMANDS tab,
The 37 bit value could be used to control channels, but I am not really sure which bit controls which frequency.
Could you please confirm if I am on right path or there is other way to control the operating frequency?
Naga.
The LSB bit ( In the channel Map Array) is corresponds to the channel -0 and so on----Refer the below figure taken from CySmart UI-
The corresponding channel frequency can be find out from the below figure --
So, based on the frequency you want to use , find the corresponding channel and configure the 'Channel Map' array accordingly.
-Gyan
