urchc_1533771
I want to control bonding by enable/disable and need change security mode from "Authenticated pairing with encryption" to "Unauthenticated pairing with encryption".
How to do this ? What a functions exist ?
HeLi_263931
Level 8
Level 8
100 solutions authored 50 solutions authored 25 solutions authored
There is  _CyBle_GapAuthReq_ which is used when your code is starting the pairing request. Maybe _ CyBle_GappAuthReqReply_ can be used on the receiving side to change configuration.
But this questions seems as if it should go to Cypress directly - maybe you should create a support case...
HeLi_263931
Level 8
Level 8
