dpf888
First question asked 5 sign-ins Welcome!
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Seeing your picture, I would try using connector:  10p
Meantime, please check if power is being supplied to the target board including the PSoC device.
moto
ADSW
50 solutions authored 25 likes received 25 solutions authored
Hello @dpf888 ,
Please check the connection between device and Miniprog, and check for the power line ( Vtarg)
From your picture, the power is off meaning the device ( psoc is off or no power ).
You should get the status of power is ON, for example :
Warm regards
Andri
ADSW
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one.
The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Andri
