songzaiwu
50 sign-ins 10 questions asked 25 sign-ins
How to solve?
Alakananda_BG
50 likes received 250 sign-ins 250 replies posted
Hi @songzaiwu ,
Please see the attached image below, you have to give the address of the hex and elf file of the bootloader here.
You can also refer to the below KBA - https://community.infineon.com/t5/Resource-Library/Bootloader-Code-Examples-for-PSoC-3-PSoC-4-PSoC-4...
Alakananda
Alakananda_BG
Hi @songzaiwu ,
Can you please check if you have given the correct path of the hex and the elf file of the bootloader in the bootloadable component.
Alakananda
songzaiwu
Can you post a routine with one step? thank you very much!
Alakananda_BG
Hi @songzaiwu ,
Alakananda
