May 21, 2021
03:05 PM
May 21, 2021
03:05 PM
Hello
I have a design that uses the 4200M device (CY8C4246azi-M445). I would like to add BLE support to this design. Can you recommend a compatible device preferably one packaged into an FCC module with built in antenna? I don't need all of the GPIOs that the CY8C4246azi-M445 has because I'm removing an LCD that will not be needed once BLE support is added.
thanks
Shawn
Labels
11:05 PM
May 23, 2021
11:05 PM
Could you please refer to the EZ BLE Creator modules from the link. Please let me know if this helps.
P Yugandhar.
11:05 PM
May 23, 2021
11:05 PM
P Yugandhar.
