GlJe_1688511
Distributor
100 sign-ins 10 likes given 50 questions asked
Hello.
I want to know a operating themperature of CY8C4247LTQ-L485.
Q is Extended Industrial.
But, a Q temperature of a CY8C4247LTQ-M475 is max 85℃
Which is the Q temperature a 85℃ or a 105℃?
Do you have the document written it?
Thanks and Best regards.
Glenn.
SampathS_11
250 sign-ins 250 solutions authored 5 questions asked
Hi Glen,
The Maximum temperature for Q is 105℃. You can find this in the datasheet for CY8C4247LTQ-L485 on the second page, right hand column.
The datasheet has specifications for both standard and extended industrial parts. Specifications for standard industrial are noted specifically with a maximum temperature of 85℃ in the datasheet, e.g., Table 2 on page 17.
Sampath Selvaraj
SampathS_11
Hi Glen,
Sampath Selvaraj
