Is anyone aware of a way to write to the user section of the SFlash via ppcli.exe or other similar means?
Thanks in advance
PSoC 4 Architecture
1. Use the PSoC4 BLE SFLASH update tool to update SFLASH
2. Open ppcli.exe from the PSoC Programmer installation directory, enter command as below figure to check whether it has been written successfully.
3. From the second figure, it shows that we can use the DAP_ReadIO read the data out easily. We only need to know the data located address.
4. Hope it can be helpful for you.
Do you know if PSoC4 BLE SFLASH update tool supports KitProg, it doesn't seem to see it? Also, is it possible to use DAP_WriteIO in the ppcli to write to User SFlash?
You can use the "DAP_WriteIO" in the PPCLI.
You also can find the PSoC4 BLE SFLASH Update tool.exe in the Programmer Installation Catalog like:
C:\Program Files (x86)\Cypress\Programmer\Examples\Misc\PSoC4-BLE-SFLASH-Update\Executable
