Why would a clock block disconnect from a net after a "find" is performed on its name?
JoWi_3984961
TopDesign.sysch PSOC 4
After it disconnects, It does not attach with wire. It looks like it does, but then it can be dragged away
with no rubber banding.
There is a warning about the clock, Asynchronous path(s) exist from ____ to __________
But the circuit works and I've been using it.
After doing a search, it disconnects and won't reattach.
Anyway to fix this?
Environment:
PSoC Creator  4.2 (4.2.0.641)
Culture: English (United States)
OS Version: Microsoft Windows NT 10.0.17763.0
CLR Version: 4.0.30319.42000
Installed CyInstaller Products:
CY8CKIT-046 PSoC 4 L-Series Pioneer Kit 1.0 Rev.*A
Peripheral Driver Library 3.0.1
Peripheral Driver Library 3.0.3
Peripheral Driver Library 3.0.4
Peripheral Driver Library 3.1.0
PSoC Programmer 3.28.3
PSoC Creator 4.2
Loaded Plugins:
Version: 4.2.0.641
Company: Cypress Semiconductor
Description: Loads component customizers.
Name: Addin Discovery
Version: 4.2.0.641
Description: Discovers PSoC Creator addins (kits, language packs, etc)
Version: 4.2.0.641
Description: Device Catalog Plugin
Version: 4.2.0.641
Description: Adds the topics available in the documentation.
Version: 4.2.0.641
Description: Adds a start page to the framework.
Name: Output Window Plugin
Version: 4.2.0.641
Description: Adds the output window
Version: 4.2.0.641
Description: The Source Code Control Manager is the central class used for SCC actions within PSoC Creator.
Name: Symbol, Schematic and SchMacro Factory
Version: 4.2.0.641
Description: The Symbol and Schematic Factory is used to load, cache, and retrieve symbols and schematics.
Name: Project Manager Plugin
Version: 4.2.0.641
Description: Adds project management related functionality.
Version: 4.2.0.641
Description: Loads the Symbol and Schematic editors
Version: 4.2.0.641
Description: Supports user files in multiple languages
Version: 4.2.0.641
Description: The Workspace Factory is used to retrieve instances of PSoC Creator workspaces.
Version: 4.2.0.641
Description: The Project Factory is used to retrieve instances of PSoC Creator projects.
Version: 4.2.0.641
Description: PSoC Creator Toolchain Manager
Name: ARM GCC Generic
Version: 4.2.0.641
Description: ARM GNU Generic
Name: ARM MDK Generic
Version: 4.2.0.641
Description: ARM MDK Generic
Name: ARM IAR Generic
Version: 4.2.0.641
Description: ARM IAR Generic
Name: DP8051 Keil Generic
Version: 4.2.0.641
Description: DP8051 Keil Generic
Version: 4.2.0.641
Description: Adds a dialog that allows the user to select a device.
Name: File Editor Factory Plugin
Version: 4.2.0.641
Description: Add file editors to the framework.
Name: Transport Framework
Version: 4.2.0.641
Description: Provides a generic device communication framework for use by other plugins.
Version: 4.2.0.641
Description: The Core Debugger provides an architecture independent framework for the common debug features.
Version: 4.2.0.641
Description: Provides debugging support for the different PSoC families through a GDB back end.
Version: 4.2.0.641
Description: Provides debugging support for FM device families
Name: Device IO Transport
Version: 4.2.0.641
Description: Provides device IO support for Cypress devices though PSoC Programmer APIs.
Name: Serial Transport
Version: 4.2.0.641
Description: Provides basic serial device support for the rest of the tool.
Version: 4.2.0.641
Description: Provides a host tool to perform bootloading operations.
Name: Background Elaborator
Version: 4.2.0.641
Description: PSoC Creator Background Elaborator.
Version: 4.2.0.641
Description: The TypeCache Factory is used to retrieve instances of TypeCaches.
Version: 4.2.0.641
Description: PSoC Fitter Plugin
Version: 4.2.0.641
Description: FM Fitter Plugin
Version: 4.2.0.641
Description: Registers resource editors with devices.
Version: 4.2.0.641
Description: Enables quick and correct development of applications that use DMA.
Version: 4.2.0.641
Description: Manages custom component tuner executables
Version: 4.2.0.641
Description: The Notice Window displays notices (status messages / errors with managed lifetimes).
LinglingG_46
500 solutions authored 1000 replies posted 10 questions asked
Hi
As my understanding, it will have no change on the schematic if you use the "find" function.
If you use clean and build, can you pass the building process?
How to understand that your project function is Ok?
Could you give me a short video about it?
Does your issue have been solved?
