Why the bootloadable project file become larger?
chwa_1570756
Level 4
Level 4
25 sign-ins 25 replies posted 10 replies posted
I have downloaded a bootloader into my board, and then try to build a bootloadable project, but I found the built file grow larger with more times building till to out of flash space.
what is the reason?
Beast regards,
Chris
Alakananda_BG
50 likes received 250 sign-ins 250 replies posted
When we try to build the project at our end, it is working fine and we not seeing the issue which you have mentioned.
Alakananda
Alakananda_BG
Can you please attach your project so that we can verify at our end.
Alakananda
This is the  result of 1st building:
This is the result of 2nd building:
With more times building, it will become larger and larger till out of flash.
Here is the attached file.
Chris
Alakananda_BG
Alakananda
