Who knows the PSoC™ 4 MCU's chip ID is ? (MPN:"CY8C4046FNI-T412T")
FFSnow
10 sign-ins 5 questions asked 5 replies posted
I have a need to determine the chip id of PSoC™ 4, but I can't found it after searching the datasheet. Can anyone know.
At the same time, i want to confirm wheter the I2C address of this PSoC.
Thx!
LeoMathews
First question asked 500 replies posted 100 solutions authored
Hi @FFSnow
Can you please use the PPCLI tool after connecting the device? The silicon ID can be obtained from running PSoC4GetSiliconID() API as shown below. But inorder to display the ID the device needs to be acquired first. Please try running the following sequence of commands in PPCLI tool:
For you 2nd query please check this thread link and check if it helps.
Thanks and Regards,
Leo
LeoMathews
Hi @FFSnow
Thanks and Regards,
Leo
I got the ppcfi tool, and begin to run the commands. But the function "PSoc4_GetSiliconID" run failed.😭
Check the API document, we found the function DAP_Acquire must to execute. But we can't success to execute it.😑
We current use the CY8CKIT-040T to test. It is PSoC 4000T CAPSENSE Evaluation Kit.
LeoMathews
Hi @FFSnow
I see that you missed the SetPowerVoltage() API call in the last post. Can you execute the same and try acquiring the device again?
Thanks and Regards,
Leo
Hi @LeoMathews
I have excute the commands again.When excute the funtion "DAP_Acquire", it error.
PSoC™ Programming CLI User Guide is locked, i have not permission to open it. QAQ.
It seems that function "DAP_Acquire" does not support CY8CKIT-040T.
Thanks and Regards,
FFSnow
LeoMathews
Hi @FFSnow
You can view the SiliconID of the device in \mtb_shared\mtb-pdl-cat2\release-v2.7.0\devices\include folder from ModusToolbox:
Thanks and Regards,
Leo
Hi @LeoMathews
I find it !!
Thank you very much!!💪
FFSnow
