I'm not particularly knowledgeable about the names of electronic hardware components - or if such items exist - or where to get them.
I'm thinking that I want to put physical headers on the J1 and J2 positions on the -043 kit so that we can use male-to-male jumper wires.
What would these be called? Can they even be found? Where?
If 1 row X 29 position headers aren't available, how would you suggest shorter headers be distributed?
Also -- can I use a USB A - USB A cable to connect the -043 to my desktop computer?
Hi Susan,
1. Most headers with 2.54-mil pitch are OK for J1 and J2. You can purchase some from shops online. For example:
2. Yes. You can use USB_A - USB_A cable to connect the -043 to your laptop.
Ryan
Hi Susan,
Ryan
In addition, pin number of headers should not be a problem. Either cutting a long one, or several shorts linking together is OK.
Ryan
