Where can I find example FM24C64 using iic?
benzhiqiang
First reply posted First like given First question asked
I search the website,download the psoc kit,but there is no code example.
I need help ,thank you
Roy_Liu
5 comments on KBA First comment on KBA 10 questions asked
You can download the CY15FRAMKIT001Setup.exe package, you will find the I2C FRAM code example in the installation path of the kit.
https://www.infineon.com/dgdl/Infineon-CY15FRAMKIT001Setup.exe-DevelopmentTools-v04_00-EN.htm?fileId...
Roy Liu
LinglingG_46
500 solutions authored 1000 replies posted 10 questions asked
1: Which kit do you download?
2:   Which one is your target?  PSoC or FM24C64(FRAM)
3: From your description, I don't understand what kind of code example you want to fine,  please describe it in details.
Roy_Liu
Roy Liu
benzhiqiang
thanks,I will look it up
