I have a CY8CKIT042. Besides that, there are some evaluation kit, for example CY8CKIT049, CY8CKIT149, etc. Please let me know difference between these kits. If there is more suitable kit for my application, I consider that using it.
Different kits use different PSoC product families. Choose the kit that fits your peripheral and ROM / RAM capacity.
Some Development Kits have Arduino Uno compatible pin headers, ready to use third party shields.
Detailed information on the kit can be obtained from this URL
https://www.cypress.com/microcontrollers-mcus-kits#psoc4
Naoaki Morimoto
Naoaki Morimoto
Basically an EVB is for evaluating the particular device mounted on that board.
For PSoC 4
PSoC 4000 (CapSense and standard MCU feature)
PSoC 4100 (4000 + Analog Block)
PSoC 4200 (4100 + Digital Block)
So if you are currently using CY8CKIT-042 (4200),
probably moving to an EVB with 4200/4200M/4200L device is safer.
CY8CKIT-149 has 4100S Plus device, so it does not have UDB.
(But it has SmartIO, though)
Now about CY8CKIT-049,
It does not have KitProg, it has only USB-Serial adapter. So programming must be done via bootloader or an external programming device such as MiniProg3, MiniProg4, or KitProg from other board.
So, IMHO, I don't recommend someone new to PSoC to use CY8CKIT-049.
Meantime, there are a couple type of EVBs
(1) Prototyping Kit
Has KitProg and most of I/Os are available for the user.
Example: CY8CKIT-043
(2) Pioneer Kit
Has some basic peripherals, some external devices, Arduino Uno type Connector, just like CY8CKIT-042
Example: CY8CKIT-044
https://www.cypress.com/documentation/development-kitsboards/cy8ckit-044-psoc-4-m-series-pioneer-kit
Since you are using CY8CKIT-042, considering CY8CKIT-044 or CY8CKIT-043 will be easier to move.
Last but not least, there are many EVBs, so please browse them and find suitable one(s) for yourself.
moto
