Dear Receiver,
I found "CE95363-Code Example" and "CE222306-Code Example" are all I2C Master code examples.
I would like to know what're their differences ?!
I2C Master just read from slave and write to slave. Why there are 2 different code example ?!
After I check these 2 codes, I found CE95363 is near my requirement. But I still feel confused about CE222306.
What's the meaning of high level master and low level master ?!
Thank you so much.
PSoC 4 MCU
HI @Tim_Shih
Thanks for waiting, I hope you are doing fine.
Technically there is no difference in code examples of CE222306 and CE95363. In the CE222306 code example, i2c communication is done by both methods High-level and Low-level implementation in two separate projects. Whereas in the CE95363 code example we are doing only High-level i2c communication.
For Your reference, I am attaching the datasheet for CE222306, you can go through it for High-level and Low-level implementations.
Please, Let us know if you have further issues.
Thank You
Best Regards
Sahil Kumar
HI @Tim_Shih
Thank You
Best Regards
Sahil Kumar
