I'm looking to stream the data read from 6ADC over BLE. I'm currently basing my code on the battery_level example but the communication is very slow -I'm getting 2 readings (2bytesx6) per second at the server side (windows computer running python script). I think I'm not using the right command to send the data. The way I'm doing it now is by using 6 services (see complete code attached) like this:
Thanks in advance for the help.
ADC_StartConvert();
ADC_IsEndConversion(ADC_WAIT_FOR_RESULT);
adcResult = ADC_GetResult16(0u);
adcResult1 = ADC_GetResult16(1u);
adcResult2 = ADC_GetResult16(2u);
adcResult3 = ADC_GetResult16(3u);
adcResult4 = ADC_GetResult16(4u);
adcResult5 = ADC_GetResult16(5u);
mvolts0 = ADC_CountsTo_mVolts(0,adcResult);
mvolts1 = ADC_CountsTo_mVolts(1,adcResult1);
mvolts2 = ADC_CountsTo_mVolts(2,adcResult2);
mvolts3 = ADC_CountsTo_mVolts(3,adcResult3);
mvolts4 = ADC_CountsTo_mVolts(4,adcResult4);
mvolts5 = ADC_CountsTo_mVolts(5,adcResult5);
CYBLE_GATTS_HANDLE_VALUE_NTF_T tempHandle;
tempHandle.attrHandle=CYBLE_PDIODE_DDIODE_CHAR_HANDLE;
tempHandle.value.val = &mvolts0; //(uint8 *)&mvolts1_int;
tempHandle.value.len=sizeof(mvolts0);
CyBle_GattsNotification(cyBle_connHandle,&tempHandle);
tempHandle.attrHandle=CYBLE_PDIODE_2_DDIODE_CHAR_HANDLE;
tempHandle.value.val = &mvolts1;
tempHandle.value.len=sizeof(mvolts1);
tempHandle.attrHandle=CYBLE_PDIODE_3_DDIODE_CHAR_HANDLE;
tempHandle.value.val = &mvolts2;
tempHandle.value.len=sizeof(mvolts2);
tempHandle.attrHandle=CYBLE_PDIODE_4_DDIODE_CHAR_HANDLE;
tempHandle.value.val = &mvolts3;
tempHandle.value.len=sizeof(mvolts3);
tempHandle.attrHandle=CYBLE_PDIODE_5_DDIODE_CHAR_HANDLE;
tempHandle.value.val = &mvolts4;
tempHandle.value.len=sizeof(mvolts4);
tempHandle.attrHandle=CYBLE_PDIODE_6_DDIODE_CHAR_HANDLE;
tempHandle.value.val = &mvolts5;
tempHandle.value.len=sizeof(mvolts5);
apiResult = CyBle_BassSendNotification(cyBle_connHandle, 0u,
0u, sizeof(batteryLevel), &batteryLevel);
BLE
1. From BLE side we recommend you to check the status of the stack before sending the BLE packet as follows) and send the notification as quickly as possible.
/* Create a new notification packet */
CYBLE_GATTS_HANDLE_VALUE_NTF_T notificationPacket;
/* Update Notification packet with the data.
* Maximum data which can be sent is equal to (Negotiated MTU - 3) bytes. */
if(CyBle_GattGetBusStatus() == CYBLE_STACK_STATE_FREE)
notificationPacket.attrHandle = CYBLE_CUSTOM_SERVICE_CUSTOM_CHARACTERISTIC_CHAR_HANDLE;
notificationPacket.value.val = buffer;
notificationPacket.value.len = negotiatedMtu - 3;
/* Report data to BLE component */
CyBle_GattsNotification(cyBle_connHandle, ¬ificationPacket);
2. Reduce the connection interval period in BLE component datasheet.
Please refer BLE throughput code example GATT Notification -Data Outgoing ( Day024_Throughput) from github (link given below):
Ganesh
Ganesh
Thanks, Ganesh,
I combined all the services' data into one and reduce the interval period to the minimum and I was able to achieve 100 samples a second.
