What happened to CY8CKIT-049-42xx? Production stopped?
JaHy_1300691
I am looking for CY8CKIT-049-42xx kit at Farnell, Mouser, RS-components... and no CY8CKIT-049 available.
The production of this kit is stopped?
Thanks, Jan
Rakshith
250 likes received 1000 replies posted 750 replies posted
Hi JaHy_1300691​,
Your observations are correct. The CY8CKIT-049-42xx kit is obsoleted.
If you can provide more information on the requirements of your application, we can suggest a PSoC device best suited for your application.
Rakshith M B
Thanks and Regards,
Rakshith M B
Rakshith
Hi JaHy_1300691​,
Rakshith M B
Thanks and Regards,
Rakshith M B
JaHy_1300691
Hi Rakshith,
thanks for response, to your more-info request:
my application are super-simple, CY8C4245AXI is more then enough (2x PWM, 8ch ADC, 2x UART).
Rather then different chip I would need a KIT with the same footprint as CKIT-049 (w/o UART-USB) since I have already PCBs to place whole KIT.
Thank you in advance for suggestion. If not, I am reconciled to create "package converter"
Hi JaHy_1300691,
Can you check CY8CKIT-043 and see if this meets your requirement? It has the CY8C4247AZI-M485 chip.
Rakshith M B
Thanks and Regards,
Rakshith M B
