What API calls and variable names to change to in the main.c file after swapping a UART to SCB blocks in the schematic?
adamelli
10 replies posted 10 likes given 10 sign-ins
First, I just found out what ISR means. I did not create this program, and have little practical experience with interrupts.
I just took out the UART (datasheet), and in its place put the SCB (datasheet).
Now the main.c file has errors (and warnings) in this function:
CY_ISR(InterruptHandlerDMXIn)
    // Read status, and clear interrupt
    int status = UART_DMX_ReadRxStatus();
    // Get location of pointer
    ptrdiff_t ptrIndex = dmxReadPtr - DMXReadBuffer;
    // Check for break
    if(status & UART_DMX_RX_STS_BREAK)
        // Reset pointer
        dmxReadPtr = DMXReadBuffer;
        // Update TX data
        writeFlag = TRUE;
        // Clear buffer
        UART_DMX_ClearRxBuffer();
    // If data ready, read data and write to next device with address skip
    if(status & UART_DMX_RX_STS_FIFO_NOTEMPTY)
        // if the pointer is smaller than the size of the DMX packet, process
        if(ptrIndex < DMX_SIZE)
            // Read data
            *dmxReadPtr = UART_DMX_ReadRxData();
            // Send the data to the next light when the pointer exceeds the address (first four bytes)
            if(ptrIndex > 4)
                UART_DMX_PutChar(*dmxReadPtr);
            // Increment pointer
            dmxReadPtr++;
        else
            // Clear buffer
  • UART..ReadRxStatus();
  • UART..RX_STS_Break
  • UART..ClearRxBuffer();
  • UART..RX_STS_FIFO_NOTEMPTY
  • UART..ReadRxData();
  • etc.
There are so many subfolders, I do not know how to go about changing the old program to accommodate the changed schematic blocks. Any pointers, and just general tutorials on how to understand what is going on in the main.c file?
(I can foresee me changing this whole program for a more recent IC.)
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Yes, I wish the maker had provided "compatibility" between these components.
Anyway, if I were you would try to create a header to bridge between those.
Something like
uart_utils.h
#ifndef _UART_UTILS_H_
#define _UART_UTILS_H_
#include "project.h"
#define UART_DMX_ReadRxStatus() UART_DMX_GetInterruptCause()
#define UART_DMX_RX_STS_BREAK  UART_DMX_INTR_RX_NOT_EMPTY
#endif /* _UART_UTILS_H_ */
and include this header in the source files which uses UART.
moto
MotooTanaka
Level 9
Level 9
I tried to create a blank project with SCB UART (UART_DMX) and tried search and fit APIs/Definitions using CY8CKIT-044.
    int status = UART_DMX_GetInterruptCause() ;
    UART_DMX_rx_ClearInterrupt() ;
    // Check for break
    if(status & UART_DMX_INTR_RX_NOT_EMPTY)
        // Reset pointer
        // Update TX data
        writeFlag = TRUE;
        // Clear buffer
        UART_DMX_CLEAR_RX_FIFO ;
            // Read data
            *dmxReadPtr = UART_DMX_UartGetByte(); //
            if(ptrIndex > 4)
                UART_DMX_UartPutChar(*dmxReadPtr);
            dmxReadPtr++;
        else
            // Clear buffer
Now the good news is that the project can be compiled,
but the bad news is that I can't check if this works within your context.
I hope that at least this can be some starting point for you.
moto
    • UART..GetInterruptCause()
    • UART..INTR_RX_NOT_EMPTY
    • UART..CLEAR_RX_FIFO
    • UART..UartGetByte
  • UART..PutChar
    • UART..UartPutChar
  • TX_Write
    • UART_DMX_tx_Write
I will likely have to change the whole program again for a newer IC. I did not create the main.c program, and do not really understand large parts of it. Is the quick and dirty way of changing the API calls and variables to just look in related word .h files?
Some of the variables deeper into the program broke, and that is where I guessed seemingly equivalent names. Although, I doubt I would have guessed something like `ReadRxStatus` would be `GetInterruptCause`.
MotooTanaka
Level 9
Level 9
Something like
uart_utils.h
moto
