Equip yourself to optimize PSoc4 MCUs for Evs at the EV Webinar. Click here to register.
PSoC™ 4 Forum Discussions
user_2457466
10 replies posted 5 replies posted 5 questions asked
I am currently in the process of implementing a communication component in verilog. The component has 3 digital inout terminals. To this i want to attach 3 different bidirectional pins.
Throughout the communication process, i will need to change the drive mode of the pins connected to the terminals. How can this be achieved in verilog. Any hints are greatly appreciated.
regards,
Martin
odissey1
Level 9
Level 9
Martin,
The bidirectional pins should be connected to bufoe, which has direction control terminal. The easy way would be to use a schematic approach, for example see this component implementation using bufoe
Component to read DS18B20 digital temperature sensors
You would have to make a "core" component in Verilog and some schematic around it. You may find an example of such encapsulation here:
DDS24: 24-bit DDS arbitrary frequency generator component
On the other side, you can find example of the bufoe instancing in the document attached
/odissey1
odissey1
Level 9
Level 9
Martin,
/odissey1
