i'm using a CY8CKIT-149 eval board and PSoC4 and i would like to measere internal temperature using a DieTemp component. How do i have to configure the ADC SAR Seq component for measuring the temperature given me by the DieTemp comp? Is there some example code for using it?
Hi @Miglio1982,
You can refer to the code example "CE195275 - Sequencing SAR ADC and Die Temperature Sensor with PSoC™ 4" in PSoC creator. Create a PSoC Creator project with the above code example from the code example panel. Select your device as 'CY8C4147AZI-S475' and follow the code example document for configurations for the device and procedure steps.
Let us know if you need further clarification.
Thank you
Best Regards
Raj Chaudhari
Hi @Miglio1982,
Thank you
Best Regards
Raj Chaudhari
