Jun 23, 2019
01:50 AM
Jun 23, 2019
01:50 AM
Hi
I would like to used the BLE pa_en functionality on a CYBLE_214015 module to trigger an interrupt.
Is there anyway to achieve this? (See attached project for my attempt)
Pete
Labels
07:17 AM
Jul 04, 2019
07:17 AM
Hello Pete,
The pin P5[0] is not connected for CYBLE214015 module so it is not possible to use pa_en. Please see page no.14 in the BLE component datasheet where it was mentioned that the power amplifier enable (pa_en) output allows you to connect a high active external power amplifier to the device. This output can be routed to the P5[0] digital output pin only.
P Yugandhar.
