yuku_4421226
My environment
OS:windows10 64bit
PSoC Creator:4.2.0
PSoC Programmer:3.28.5
KIT: CY8CKIT-044, CY8CKIT-026
I want to use LIN and I2C at the same time. However both communication use SCL(4.0) and SDA(4.1) port in example program. Can I use both if I use other ports as SCL and SDA?
Yuki Kurihara
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
PSoC 4200M has 4 SCBs.
P4[0] and P4[1] are used by SCB[0].
So if you assign the other I/F to other SCB such as
SCB[1] (P3[0], P3[1]) or SCB[2] (P5[0], P5[1]) or SCB[3] (P7[0], P7[1]),
you should be able to use both same time.
moto
MotooTanaka
Level 9
Level 9
moto
Hi Moto-san,
I'll try to follow your advice.
Thank you your help!
Yuki Kurihara
