D_Sd_3235936
Level 4
Level 4
25 sign-ins 50 questions asked 25 replies posted
Receiving a CYBLE 224116 (4.2) to upgrade from 224110 (4.1)
Do I need to make any specific changes in the Top Design/Code?
VenkataD_41
The best practice for upgrading the project from one module to new module is as follows:
1. Open the old project (project with 224110) in your case in new version of PSoC Creator (4.2 in your case) and upgrade all the components and build it. Ensure that build is sucess.
Find the path Project --> Update components to update the components.
2. Create an empty project (in creator 4.2)  for the new module that you are going to port to. It is CYBLE 224116 in your case.
3. Copy all the contents from old project's schematic to the new project. Copy all the necessary files and replace main.c . Build it. If any build errors come that may be because the limitation of the features in new module (i.e. CYBLE 224116) in your case.
Another advice is please use latest version of PSoC Creator i.e. PSoC Creator 4.4 for your development.
Hope this helps. Please update if you have any queries.
Ganesh
VenkataD_41
Ganesh
