Does anyone know if there is planned development for the PSoC4 CY8C4A Analog Coprocessor? Is it safe to assume that it will continue to be supported for the coming years? The CY8CKIT-048 development board for this chip is getting hard to find and is labeled as "End of Life", so I'm getting a little worried that starting a new project with this chip could be risky. If we could get assurance that this chip will continue to be supported for the coming years, it would really help. Thanks!
PSoC 4 MCU
Hi @sreese,
Thanks for your patience.
I can say that the PSoC4 CY8C4A Analog Coprocessors are going to be supported for the upcoming years. This product will be available for quite some time.
Thank you
Best Regards
Raj Chaudhari
Hi @sreese,
Thank you
Best Regards
Raj Chaudhari
Hi Raj, thanks for the assurance! If this is the case, do you know why the development kit is entering end of life? Is a new development kit going to be available? Thanks.
Hi @sreese,
Can you please point out the reference for the above concern? So, I can verify it.
Thank you
Raj Chaudhari
Hi Raj, if you go to Mouser to buy a development kit, CY8CKIT-048, you will see very low stock and "end of life" listed in the lifecycle. Attached is a screenshot from Mouser. Digikey lists this same part as obsolete. Thanks.
Hi @sreese,
The CY8CKIT-048 is indeed obsolete now. There are no plans for now to support it. It can be offered to market again but no concrete plan.
Thank you
Best Regards
Raj Chaudhari
